Dear Everbody, I have generated a pool of idf file through an optimization process while modifying facade characteristics (notably the position and length of the overhang and dimensions of the windows). I would like to have a graphical rendering for each idf. There is between hundred and several thousand idf files so I am searching for a batch processing method. Can I do that though ruby scripting and open studio? Or using energyplus dxf export capability?
Thanks for your help, Adrien
