Beopt 2.7 Error: Invalid XML
Hi All,
I am currently running Beopt with multiple cases. Each case has minor geometry changes and different design options selected. The first two cases fail to run, while the other 10 run successfully. The error I am receiving is:
1.xml: Error: Invalid xml File.
Has anyone run into this issue with Beopt 2.7 and found a fix?
Thanks!
Hi All,
Thanks!
