HVAC for PassivHaus
Hi!
I am trying to simulate a PassivHaus in energyplus via OpenStudio and I am finding several problems with that. I tried with the following layout, but it doesn't do anything. I want to keep the inside temperature about 18-20ºC always, working with a heat exchanger using the exhaust air to take the heat in order to reheat the outdoor air when it comes in (sorry for my bad english)
I attached a few images about I want to do. Thank you very much. I am so stressed with this.
My layout --> https://www.dropbox.com/s/gepzb8np93ui3jt/myhvac.png?dl=0
What I want to represent --> https://s-media-cache-ak0.pinimg.com/736x/c5/3c/4c/c53c4c7137c22182066b4e082dc5cc1f.jpg
Another one --> http://www.soloheatinginstallations.co.uk/images/heat_recovery_ventilation_system.jpg
HVAC for PassivHaus
Hi!
HVAC for PassivHaus
Hi!
I am trying to simulate a PassivHaus in energyplus EnergyPlus via OpenStudio and I am finding several problems with that. I tried with the following layout, but it doesn't do anything. I want to keep the inside temperature about 18-20ºC always, working with a heat exchanger using the exhaust air to take the heat in order to reheat preheat the outdoor air when it comes in (sorry for my bad english)air.
My layout --> https://www.dropbox.com/s/gepzb8np93ui3jt/myhvac.png?dl=0layout:
My layout
What I want to represent --> https://s-media-cache-ak0.pinimg.com/736x/c5/3c/4c/c53c4c7137c22182066b4e082dc5cc1f.jpgrepresent:
Another one --> http://www.soloheatinginstallations.co.uk/images/heat_recovery_ventilation_system.jpgone:
HVAC for PassivHaus
I am trying to simulate a PassivHaus in EnergyPlus via OpenStudio and I am finding several problems with that. I tried with the following layout, but it doesn't do anything. I want to keep the inside temperature about 18-20ºC always, working with a heat exchanger using the exhaust air to preheat the outdoor air.
My layout:
My layout
What I want to represent:
Another one:
HVAC for PassivHaus
My layout:
My layout
Another one:
Edit -----
Okay, now, I've included the ERV in my ThermalZone, and edited it. I found some problems here...
  1. The first one. I don't know how to draw the airloop to add the ERV. I tried to add it in the one I posted (Link “My layout”) but I got a failed simulation. I am so lost here.
  2. When I am editing the control of my HVAC, I selected "Siempre 20º" (Always 20ºC), but in the results I don't get that. The temperature comes from 10 to almost 30ºC.
  3. When I am trying to edit the ERV, the Air Inlet Node Name and Outlet have a very strange name, so I can't identify the correct ones. In addition, I don't have the proper air-loop to know that nodes.
  4. Another question that I have is about the schedule that I need for Heating Thermostat and Cooling Thermostat. Should I use time? temperature? always on?
  5. I don't know either what type of SetPointManager use to set the temperature always in range between 18-24ºC
I am working with OpenStudio since November for my Final Project, and this is a completely chaos.
I put some links to helpful screenshots of what I want to explain.
image description image description image description C:\fakepath\4.JPG image description
HVAC for PassivHaus
My layout:
My layout
Another one:
Edit -----
image description image description image description C:\fakepath\4.JPGimage description image description
HVAC for PassivHaus
My layout:
My layout
Another one:
Edit -----
image description image description image description image description image description
Edit 2 ------
I've deleted the air-loop, inserted a Recovery Ventilator in the Zone Equipment. But now, when I try to simulate, I get an error that didn't happened before... It says: Object=Wateruse:connections, name=Water use connection, Required Field=Water Use Equipment 1 Nambe (was blank)..
I've checked all the water system and the equipments has name. I am so confused cause I dind't change anything else and this error appeared.. Here some image references.
HVAC for PassivHaus
My layout:
My layout
Another one:
Edit -----
Edit 2 ------
Edit 3 -----
I've solved the Water Equipment error. When I deleted the old thermal zone, it disappeared from Spaces, thats all. Now I can run the simulation, but, I get the same results than before... Minimums temperatures of 14ºC and maximums of 28ºC (average), with the same graph. I tried to activate cooling and heating system from ERV's options (cooling setpoint 24ºC and heating setpoint 18ºC) but the temperature doesn't change anything... Any suggestion?
Apart from that, how can I know that this nodes are the correct ones (Air inlet/outlet)? Which ones should I select?
