Hi, I have a building that has 2 chilled water loop with different loop temperature. Each is cooled by a water-to-water heat pump and providing chilled water to different equipment. Is it possible to have 2 separate chilled water loop with water-to-water heat pumps rejecting heat to the same hot water loop in EnergyPlus?
