Caveat: I can spell "EMS", but have very limited familiarity with it. I've pored over the example files and think I've got syntax and organization correct ... but it still doesn't work.
Nonetheless, I think I'm trying to do something fairly simple - turn on a fan when the sun is down and the indoor temp is warmer than the outdoor temp. Simple or not, EnergyPlus tells me it cannot process the line :
"IF (SunIsUp==0) && (OutdoorTemp<23.9) && (ZoneTemp-RSP4th:RSP>29.4)" in the code below. If you can give me a clue why that is, I'll be grateful.
EnergyManagementSystem:Sensor, OutdoorTemp, Environment, Site Outdoor Air Drybulb Temperature;
EnergyManagementSystem:Sensor, ZoneTemp-RSP4th:RSP, RSP4th:RSP, Zone Mean Air Temperature;
EnergyManagementSystem:Actuator, NightClgActuator, Sched_NightClg, Schedule:Compact, Schedule Value;
EnergyManagementSystem:ProgramCallingManager, NightClg MgmtSys1, BeginTimestepBeforePredictor, NightClgControl1;
EnergyManagementSystem:Program, NightClgControl1, IF (SunIsUp==0) && (OutdoorTemp<23.9) && (ZoneTemp-RSP4th:RSP>29.4), SET NightClgActuator = 1.0, ELSE, SET NightClgActuator = Null, ENDIF;
