The default InteriorShade for OS Radiance, blinds.xml has a negative thickness when imported into WINDOW7.4. Should I be concerned about results in OS Radiance?
These blinds seem to have been generated very similarly to the procedure outlined here: https://www.radiance-online.org/learning/tutorials/Tutorial-genBSDF_v1.0.1.pdf
