I have simulated the building using open studio to find the cooling load.In result its showing district cooling load,is there any difference between cooling load and district cooling load?if its what is the difference?
| 1 | initial version |
| 4 | retagged |
I have simulated the building using open studio OpenStudio to find the cooling load.In result its load.
In results, it's showing district cooling load,is load, is there any difference between cooling load and district cooling load?if its load? If so, what is the difference?
| 6 | retagged |
I have simulated the building using OpenStudio to find the cooling load.
In results, it's showing district cooling load, is there any difference between cooling load and district cooling load? If so, what is the difference?
