I'm using the "Trp LoE Film (66) Bronze 6-13 (Air)" windows downloaded from the BCL library. In these kind of windows there is a center layer called "Coated Poly 66". What material is this?
1 | initial version |
I'm using the "Trp LoE Film (66) Bronze 6-13 (Air)" windows downloaded from the BCL library. In these kind of windows there is a center layer called "Coated Poly 66". What material is this? Has anyone any pic about this window?
I'm using the "Trp LoE Film (66) Bronze 6-13 (Air)" windows downloaded from the BCL library. In these kind of windows there is a center layer called "Coated Poly 66". What material is this? Has anyone any pic about this window?window? Can this window be a good window for offices?
4 | retagged |
I'm using the "Trp LoE Film (66) Bronze 6-13 (Air)" windows downloaded from the BCL library. In these kind of windows there is a center layer called "Coated Poly 66". What material is this? Has anyone any pic about this window? Can this window be a good window for offices?
5 | retagged |
6 | retagged |
