Has anyone came across the following fortran error within eQUES v3-65 and if so are there any suggestions on how to get around it?
forrtl: info (58): format syntax error at or near (Note: u-values include outside air film)'//73X,'LOCATION OF ORIGIN'/51X, 'GL
The best solution I have found to get around this error is run the model on a 32 bit machine running Windows XP; the 64 bit machine running Windows 7 will result in this error every time which ultimately crashes the program.
