I am using PAT with a base model that has no windows. I'm running a WWR measure for each cardinal direction and then three Add Daylight Sensor measures for specific space types. I run the baseline, baseline w/o sensors, baseline w/sensors as my three design alternatives primarily to see how much savings there are with adding the daylight sensors versus no sensors. Results are the same though. I've looked at the generated osm files in these two design alternatives and the windows are generated as expected in both, as are the sensors placed in the last design alternative. I review the PAT outputs on the Run tab for each of these alternatives as well: while the space types for the daylight sensors are shown as being recognized, there is an NA or Not Applied reported for each daylight sensor measure. I'm confused why on the one hand all space types are recognized for sensor placement, but they are Not Applied. All the while, sensors are actually placed in the model as reflected in the osm file for the alternative that has the place sensor measures.
