Hi,
This is in reference to the zone conditions table in openstudio report which represent hours and humidity spent in temperature and humidity range. Just wanted to understand why it shows hours in higher temperature range (78-83) /Humidity >80 when the setpoint is 74 and desired humidity is < 60%. Which parameter or control I have to use to ensure that there is no hours above 76 degrees and >60% humidity.
