Changing window properties as a variable in OpenStudio Analysis Spreadsheet
I have been trying to find a way to change window properties such a U-value, SHGC and visable transmitance as a variable in the analysis spreadsheet so that i can observe the impact of different windows.
I havent been able to find a measure that can do this directly so i tried using "ReplaceExteriorWindowConstruction" instead and thought that maybe that could work, even though its a choice argument. So i renamed all me window constructions from 1-6 and added the discrete distribution from 1-6 (This is shown in the figure below):
It did not work and i got the following error:
Failed with Could not set variable 'construction' of value 4 on model
If anyone knows how to work around this or where to find a better measure for the job i would be happy to hear from you :)
