Dear all
I have downloaded the Genopt 2.0.0. I'm going to use Genopt for optimization in TRNSYS, In the TrnOpt settings, I have used the directory where the GenOpt.class is located. But running the example of optimization, It can not find the genopt program. I have tried it by locating genopt in other drives also, but it doesn't work. do you have any comment for me ? the error is : "Genopt could not be found, please check the directory in settings"
Thank you
