Hi all,
I am running into an issue with the energyplus property Meter:Custom. I have a building that has residential portion and commercial - and I am creating two separate meters so that I can assign different rate structures.
The issue I am running into is in creating the residential meter. Essentially in order to create the residential meter I created individual meters for each end use for all my residential thermal zones. I then tried to add all my individual residential end use meters into a custom ResidentialElectric meter. Example below:
Meter:Custom,
ResidentialLighting,
Electricity,
ResZone-1,
Lights Electric Energy;
Meter:Custom,
ResidentialRecepticle,
Electricity,
ResZone-1,
Electric Equipment Energy;
Meter:Custom,
ResidentialHeating,
Electricity,
CoilHtg_ResZone-1,
Heating Coil Electric Energy;
Meter:Custom,
ResidentialElectric,
Electricity,
ResidentialLights,
ResidentialHeating;
Now - when checking the mtd file i see that all the variables set in meters ResidentialLighting, ResidentialRecepticle, and ResdientialHeating are all there. But the meter ResidentialElectric is blank - and when output in the meter.csv file shows 0 energy. My understanding is that a custom meter has the same property as any other meter. I was wondering if anyone has had experience in creating a custom meter that adds other custom meters, or if this is even a possibility.
Thanks
