Hi there I hhave an issue about "Rotate building" open studio measure. My task is discover the optimal orientation of my building that is a low energy building without HVAC. My only parameter is the internal temperature. So, if I use the PAT , the tool gives out just the energy demand of the building depending on the orientation. But my building has not energy demand cause it has no HVAC system. How can I choose the correct orientation? I would like to get the output as "zone conditions", that means temperatures, not energy. How can I manage this stuff?
