Hi,
Is there a way to set up the .idf to use the weather file given to EP without having the objects Site:Location and SizingPeriod:DesignDay? I ask because I want to know if I can set up EP parametric simulations in which I use the same .idf file for different locations and then I only change the weather file provided in each run.
Thank you.
