I'm trying to use the Create Baseline Building measure to develop the 90.1 2010 baseline. The measure runs but does not complete after 12 hours time. After I give up and hit cancel I get the attached output (some repetition removed for brevity). I'm not sure how much of this due to canceling in mid run or some issue with the model. I am able to execute whole system HVAC measures (such as aedgofficevav etc.) on this model without similar issues, and the models simulate ok, more or less.
Any thoughts would be appreciated.
DL is deprecated, please use Fiddle
[BOOST_ASSERT] <2> Assertion polygon.inners().empty() failed on line 561 of class std::vector<class openstudio::Point3d,class std::allocator<class openstudio::Point3d> > __cdecl openstudio::verticesFromBoostPolygon(const class boost::geometry::model::polygon<class boost::geometry::model::d2::point_xy<double,struct boost::geometry::cs::cartesian>,1,1,class std::vector,class std::vector,class std::allocator,class std::allocator> &,class std::vector<class openstudio::Point3d,class std::allocator<class openstudio::Point3d> > &,double) in file E:\Git\OS1\openstudiocore\src\utilities\geometry\Intersection.cpp.
[utilities.geometry.join] <1> Union has inner loops
[utilities.geometry.joinAll] <1> Expected polygons to join together
[openstudio.model.Space] <0> For BLDG1_F1_OFF_EXT_NNE, the sec_sidelit daylight area calculations hit limitations. Double-check and possibly correct the fraction of lights controlled by each daylight sensor.
[openstudio.model.Space] <0> For BLDG1_F1_OFF_EXT_NNW, the pri_sidelit daylight area calculations hit limitations. Double-check and possibly correct the fraction of lights controlled by each daylight sensor.
[openstudio.model.Space] <0> For BLDG1_F1_OFF_EXT_NNW, the sec_sidelit daylight area calculations hit limitations. Double-check and possibly correct the fraction of lights controlled by each daylight sensor.
[openstudio.standards.Space] <0> BLDG1_F1_VOID is a plenum, but could not find a floor with a space below it to determine if plenum should be res or nonres. Assuming nonresidential.
[openstudio.energyplus.ForwardTranslator] <0> OS_ProgramControl is not currently translated
[utilities.idf.WorkspaceObject] <0> Object of type 'Schedule:Constant' and named 'Always On Discrete', points to an object named OnOff 1 from field 1, but that object cannot be located.
[utilities.idf.WorkspaceObject] <0> Object of type 'Schedule:Constant' and named 'Always Off Discrete', points to an object named OnOff 2 from field 1, but that object cannot be located.
[utilities.idf.WorkspaceObject] <0> Object of type 'Schedule:Constant' and named 'Always On Continuous', points to an object named Fractional 1 from field 1, but that object cannot be located.
[openstudio.runmanager.LocalProcess] <1> Starting LocalProcess: C:/Program Files/OpenStudio 1.14.0/share/openstudio/EnergyPlus-8-6-0/energyplus.exe
[openstudio.model.Model] <0> The run completed but had the following severe errors: DetermineShadowingCombinations: There are 1 surfaces which are casting surfaces and are non-convex. ...Shadowing values may be inaccurate. Check .shd report file for more surface shading details ...Add Output:Diagnostics,DisplayExtraWarnings; to see individual severes for each surface.
[openstudio.model.Space] <0> For BLDG1_F1_OFF_EXT_NE, the pri_sidelit daylight area calculations hit limitations. Double-check and possibly correct the fraction of lights controlled by each daylight sensor.
[openstudio.model.Space] <0> For BLDG1_F1_OFF_EXT_NE, the sec_sidelit daylight area calculations hit limitations. Double-check and possibly correct the fraction of lights controlled by each daylight sensor.
[openstudio.model.Space] <0> For BLDG1_F1_OFF_EXT_NNE, the pri_sidelit daylight area calculations hit limitations. Double-check and possibly correct the fraction of lights controlled by each daylight sensor.
