Can i implement the BIPV as a window by energyplus? Is it possible to implement BIPV window that affect the indoor thermal environment?
I saw the IO-reference , and read the heat transfer integration mode, but they only mentioned about module temperature.
Is this part interact with indoor environment dynamically?
Thank you.
