Unused Non-Parent Objects
Dear forum, I'm casting about, trying to figure out why: * zones are not meeting their setpoint * there is apparently no recognized value for the zone node's "System Node Setpoint Temperature" for output:variable (it displays as a large negative value), despite using a normal combination of SetpointManager:SingleZone:Reheat and ZoneControl:Thermostat for my single zone air loops
As I look for clues, I see in the .SVG file that all of the SetpointManager:SingleZone:Reheat objects are identified as "Unused Non-Parent Objects". I'm fairly sure that may have displayed in the past, but I never had good reason to dig into it before. A search of the IO Ref and Engineering Ref does not result in anything....
So, may I please have some ideas about: 1) what may cause the zone node to have no associated setpoint value? 2) whether an "unused non-parent object" is a problem?
Thanks in advance for your insights.
p.s., In case you're interested and able to take a look, the IDF is here: https://www.dropbox.com/s/j3eabg8n3q3mfhx/Prototype%20170112%20No%20DOAS.idf?dl=0
Dear forum, I'm casting about, trying to figure out why: * why:
  • zones are not meeting their setpoint * setpoint
  • there is apparently no recognized value for the zone node's "System Node Setpoint Temperature" for output:variable (it displays as a large negative value), despite using a normal combination of SetpointManager:SingleZone:Reheat and ZoneControl:Thermostat for my single zone air loops
As I look for clues, I see in the .SVG file that all of the SetpointManager:SingleZone:Reheat objects are identified as "Unused Non-Parent Objects". I'm fairly sure that may have displayed in the past, but I never had good reason to dig into it before. A search of the IO Ref and Engineering Ref does not result in anything....anything...
So, may I please have some ideas about: 1) about:
  1. what may cause the zone node to have no associated setpoint value? 2) value?
  2. whether an "unused non-parent object" is a problem?
p.s., In case you're interested and able to take a look, the IDF is here: https://www.dropbox.com/s/j3eabg8n3q3mfhx/Prototype%20170112%20No%20DOAS.idf?dl=0here
