asked 8 years ago
BL's avatar
Openstudio Error with HW Two Pipe Induction Terminal
HW Two Pipe Induction Terminals are added into my loop, shown in figure below. It is connected to the hot water loop and there is no cooling coil in the terminal. I received following error messages. What does that mean ? And there is no cooling coil in the unit, is this a Openstudio Bug ?
* Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 6 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 11 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 12 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 23 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 7 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 8 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 13 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 14 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed. * Severe * GetCoilWaterInletNode: Could not find Coil, Type="" Name="" * ~~~ * In AirTerminal:SingleDuct:ConstantVolume:FourPipeInduction = HW TWO PIPE INDUCTION TERMINAL 24 * ~~~ * ..Only Coil:Cooling:Water or Coil:Cooling:Water:DetailedGeometry is allowed.
HW Two Pipe Induction Terminals are added into my loop, shown in figure below. below. It is connected to the hot water loop and there is no cooling coil in the terminal. I received following error messages. What does that mean ? And there is no cooling coil in the unit, is this a Openstudio Bug ?
A file that can replicate the error is in this link link text
