EnergyPlus 8.5 taking 9 times longer than EnergyPlus 8.5
Having updated some of my osm and idf files from OS 1.11/1.13 and EP 8.5 to 8.6, I have observed with dismay that with updated files simulation time is considerably longer. E.g.: a model that used to take appr. 12 minutes for a 1-year simulation under EP 8.5 now after simple update to EP 8.6 needs 1 h 51 minutes (!) . The simulation results are similar but the time consumption has exploded. This problem also occurs when using Openstudio 1.14.
  • Are there other users who have observed similar worrying deterioration with EP 8.6 ?
  • Is there anything that can be done - keeping the same accuracy levels - to achieve similar simulation times as with EP 8.5. ?
  • What can developers say to explain this strange behavior ? Are there plans to investigate possible weaknesses in new algorithms ?
Technical details of my transition:
EP 8.5 under Windows 7 (2 CPUs), 32 bit;
EP 8.6 (64 bit stand-alone, 32 bit bundled with OpenStudio) under Windows 10 (4 CPUs) 64 bit;
