Is there no 'scan for tools' option in OS 2.0?
I am not able to get the Openstudio results in the Results summary page, which now displays just the Energyplus results Here. Previously. when this happened (rarely) in the older versions, I used the 'scan for tools' option under the Preferences tab to locate the latest version of Eplus and Ruby. This option isn't available under V 2.0.0, in the Menu.
Is there a workaround to this for the new version different from OS 1.14? Or is there something else that has to be done to get the Openstudio results summary?
I am not able to get the Openstudio results in the Results summary page, which now displays just the Energyplus results as follows:
HereHere. Previously.
Previously, when this happened (rarely) in the older versions, I used the 'scan for tools' tools' option under the Preferences tab to locate the latest version of Eplus EnergyPlus and Ruby. This option isn't available under V OS 2.0.0, in the Menu.
I am not able to get the Openstudio results in the Results summary page, which now displays just just the Energyplus results as follows:
Here
Previously, when this happened (rarely) in the older versions, I used the 'scan for tools' option under the Preferences tab to locate the latest version of EnergyPlus and Ruby. This option isn't available under OS 2.0.0, in the Menu.
