Openstudio run failed after Energyplus completed (problem relating to DDY file)
Hello,
I got a problem about Openstudio running. I am using Openstudio 1.14.0. When the DDY file is imported, the Energyplus simulation can be completed, but the Openstudio running is failed. The stderr gives me following error:
DL is deprecated, please use Fiddle
(erb):112:in block in run': undefined methodgsub' for nil:NilClass (NoMethodError)
from (erb):110:in `each'
from (erb):110:in `run'
from C:/Program Files/OpenStudio 1.14.0/ruby-install/ruby/lib/ruby/2.0.0/erb.rb:849:in `eval'
from C:/Program Files/OpenStudio 1.14.0/ruby-install/ruby/lib/ruby/2.0.0/erb.rb:849:in `result'
from C:/Users/w_lin13/AppData/Local/Temp/OpenStudio.aF8640/resources/run/6-UserScript-0/user_script.rb:235:in `run'
from in.rb:396:in `<main>'
Hello,
I got a problem about Openstudio OpenStudio running. I am using Openstudio 1.14.0. OpenStudio 1.14.0. When the DDY file is imported, the Energyplus EnergyPlus simulation can be completed, but the Openstudio OpenStudio running is failed. failed.
The stderr stderr gives me following error:
Fiddle (erb):112:in block in run': undefined methodgsub' for nil:NilClass (NoMethodError)
(NoMethodError) from (erb):110:in `each'
`each'
`run' from C:/Program Files/OpenStudio 1.14.0/ruby-install/ruby/lib/ruby/2.0.0/erb.rb:849:in `eval'
`eval' from C:/Program Files/OpenStudio 1.14.0/ruby-install/ruby/lib/ruby/2.0.0/erb.rb:849:in `result'
`result' from C:/Users/w_lin13/AppData/Local/Temp/OpenStudio.aF8640/resources/run/6-UserScript-0/user_script.rb:235:in `run'
`run' from in.rb:396:in `<main>'
`<main>'
