Hi,
Hi,
I´m trying to generate water to air heat pump parameters using the "WaterAir_PE_Cooling" Spreadsheets, the problem is all the coefficient generated produce severe errors in energyplus.
We are using TRANE catalog data and DAIKIN catalog data, and the final result is the same.
Reading the information, the catalog data are for R410 equipment's and the tool is for R22 equipment's, can this influence the final result? Can you help me whats i´m doing wrong?
In the showed link you can find 5TR TRANE water to air hp data used if some body want to make the exercise.
https://we.tl/TX6MssLuh5
Is there an idf file with reference water to air hp dataset?
Thank
