I used openstudio to build the building model and simulate in energyplus, but this project has some errors as follow: * Severe * IP: IDF line~13 Multiple occurrences of Unique Object=Version * Severe * IP: Other miscellaneous errors found in input * Severe * IP: Out of "range" values and/or blank required fields found in input * Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. I'm a new user, so if anyone could give me some advices, many thanks.
