Water to air hp coefficient generator
Hi,
I´m trying to generate water to air heat pump parameters using the "WaterAir_PE_Cooling" tool, but i don´t know why the lost coefficient is always higher than 0.
I´m using catalog data from different manufacturers, but always the result is the same and the errors are to high.
Can somebody help me showing to me the mistake?
The next link include the file with manufacturer data.
https://we.tl/lMSIb6b57O
Hi,
I´m trying to generate water to air heat pump parameters using the "WaterAir_PE_Cooling" tool, but i don´t know why the lost coefficient loss-factor is always higher than 0.
https://we.tl/lMSIb6b57O https://we.tl/lMSIb6b57O
Hi,
I´m trying to generate water to air heat pump parameters using the "WaterAir_PE_Cooling" tool, but i don´t know why the loss-factor is always higher than 0.
Water to air hp heat pump coefficient generator
Hi,
Water to air heat pump coefficient generator
Hi,
https://we.tl/lMSIb6b57Ohttps://we.tl/slPWtHxTQb
Hi,
Hi,
