when I want use "Tariff_Selection_Flat", the simulation is failed, the output are:
DL is deprecated, please use Fiddle
C:/Program Files/OpenStudio 1.12.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:in `require': cannot load such file -- C:/Users/sdl06/AppData/Local/Temp/OpenStudio.M18760/resources/run/3-UserScript-0/mergedjob-0/resources/os_lib_helper_methods (LoadError)
from C:/Program Files/OpenStudio 1.12.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:in `require'
from C:/Users/sdl06/AppData/Local/Temp/OpenStudio.M18760/resources/run/3-UserScript-0/mergedjob-0/user_script.rb:4:in `<top (required)>'
from mergedjob-0/in.rb:103:in `load'
from mergedjob-0/in.rb:103:in `<main>'
Does somebody help me to figure out what's happen?
