How to assigning separate Fresh Air Handling Unit with Fan Coil Unit in DB?
Dear Fellows,
The building that I am auditting has 3 separate Fresh Air Handling Units for entire building and Fan Coil Units for each room. I figured out how to assign the FCUs in DB but the problem is i need to assign FAHUs also along with the FCUs. Is it possible? Which tab can I use to assign separately the FAHUs with the FCUs. Please reply.
Tonnes of thanks.
