I am running OpenStudio 1.13.0 and PAT 1.13.0 on Windows 7 Pro. I can run PAT just fine, and it generates results, but I am finding that I cannot export the results to a spreadsheet, nor can I select them off the report tab and copy them to a spreadsheet. When I try to File -> Export XML Report, the resulting zipped XML file is basically empty. When I try to File -> Export Analysis Spreadsheet, it fails outright with an error message. I am extremely happy I have made it this far, but all that work might have been in vain if I cannot find a way export the numbers to make pretty graphs from!
