Custom Create DOE prototype building measure
Dear all,
I would like to create a custom measure, where I apply all the code of the Create DOE prototype measure to my osm file except for the part where the geometry of my osm is changed. In other words I want to keep the original geometry of my osm file while still applying the measure.
Is this possible?
I tried to do this by modifying the Prototype.Model file in the openstudio-standards to contain a new create_prototype_building method (called create_prototype_building_TOCore) which is exactly the same as the create_prototype_building method except for the fact that the load_geometry method is not called.
My new measure calls the create_prototype_building_TOCore method instead of the create_prototype_building method.
The code compiles but when I look in the output folder that the measure creates there is simply nothing there.
Any pointers or suggestions on the best way to approach this would be greatly appreciated.
Dear all,
Is this possible?
Dear all,
Is this possible?
Dear all,
Is this possible?
