EnergyPlus: Control strategy - hysteresis
Hey!
I want to implement the following control-strategy:
  • If the room temperature is below 19°C, the heating systems should be on until the temperature is 25°C
  • Once the temperature is 25°C, the heating system should be switched off until the temperature is again below 19°C
I think this control strategy is often called "hysteresis" (see http://nearbus.net/wiki/images/c/c0/Hysteresis_window.png)
Thank you very much for your help
Hey!
Is there an integrated module or do I have to use EMS?
Hey!
