Defining demand charge for three block rates
I am trying to define the tariff for the time-of-day rates defined as -
My
confusion is are trying to use the three
block blocks
applicable at the same time,
i.e., i.e.,
for peak hour in June is it going
to to
be (8.03+15.03+16.12)? This is
for for
each 1/2 hour max demand, isn't
this this
too high?
the The last
rate says rate(16.12) says
'low tension
only'?
only'? Is this correct
understanding? While other
months months
the max is (5.17+11.08) for
demand charges.
demand
charges. How to define the
TemiOfUseSchedule TimeOfUseSchedule for the
common common
interval of 8 am to 6 pm (as
peak(1) peak(1)
and mid
peak(4))?
peak(4))? (EnergyCharges
is is
small at $0.008 with no peak rates.)
How will the off-peak (3) for winter and
summer be aggregated ? Only one variable is automatically generated for 'offPeakDemand'.
