OSM Diagnostic Script Doesn't Resave File
I want to run the OSM diagnostics to remove some very degenerate surfaces. I've done this before and usually the script saves a new file called "filename_diagnostics.osm" after running. The last few times I've tried it does save anything after running. Any ideas on how I can get it to resave the file again so I can use the changes it makes? Thank you!
