In OpenStudio, where does one enter the "minimum fan power ratio" for variable volume fans?
I am looking to model some older fans using the performance curves outlined in the ANSI/ASHRAE/IES Standard 90.1-2010 Performance Rating Method Reference Manual on page 164, and I can not figure out how to define the minimum fan power ratio.
Thank you in advance.
