Hello,
It seems that the OS Sketchup plugin cannot be loaded in the latest Sketchup version 2017
I've installed Sketchup Make 2017 and then OpenStudio 1.13, the extension does not appear on the SU interface I tried to install it manually using the new extension manager in SU but there aren´t rbz files on any of the OS folders
I did move the folders as indicated here http://nrel.github.io/OpenStudio-user-documentation/help/troubleshooting/ After that, OS appears in the extensions manager but it doesn´t work
I presume the same issue happens with SU Pro 2017
In addition, SU Make 2016 is not available for download (although SU PRO 2016 is) so this is an issue for new installs
Is there any way to sort it out?
Thanks
