i'm using the " Set Exterior Roof Assembly to User Input U Value" doesn't seem to work measure and i keep getting the same results no matter what value i input as a U-value for the exterior roof in my model ? Osm Model Regards
| 1 | initial version |
| 2 | No.2 Revision |
i'm using the " Set Exterior Roof Assembly to User Input U Value" measure and for some reason it doesn't seem to work measure and i keep getting the same results no matter what value i input as a U-value for the exterior roof in my model ?
Osm Model
Regards
| 3 | retagged |
i'm using the " Set Exterior Roof Assembly to User Input U Value" measure and for some reason it doesn't seem to work and i keep getting the same results no matter what value i input as a U-value for the exterior roof in my model ? Osm Model Regards
| 4 | retagged |
| 5 | retagged |
