I have a set of SHR modifier curves that I would like to use with a Coil:Cooling:DX:Multispeed object. I've gone through all the fields of the object many times but I can't seem to find the ones dedicated to SHR modifier curves. I've checked the Engineering Manual for this object and it says that supposedly you can specify SHR curve fits for each speed:
Each speed has a set of corresponding performance information at rated conditions along with curve fts for variations in total capacity, SHR, energy input ratio and part-load fraction to determine the performance of the unit at part-load conditions
Did I miss a field in the object? Is there a typo in the documentation? If yes, is there a reason why it is not possible to specify SHR modifier curves for this object?
