Cooling water coil selection
Hi,
For a project located at 2500 Mt over sea level, i´m not sure if the size sown is related to 0 mt over sea level (standard selection) , because the results does not match.
In the picture, the 889590.95 Watt displayed is the total coil, equal to the sensible coil because of the humidity entering to the coil is the same leaving the coil. If you try the manual calculations this value is the total load without applying the height correction factor.
But i´m not sure if EP show the result in this way.
can someone clarify the issue?
Is there a way to show the corrected selection.
click to hide/show revision 2
No.2 Revision
Hi,
For a project located at 2500 Mt over sea level, i´m not sure if the coil size sown shown is related to 0 mt over sea level (standard selection) , because the results does not match.
Hi,
For a project located at 2500 Mt over sea level, i´m not sure if the coil size shown is related to 0 mt over sea level (standard selection) , because the results does not match.
