Energy Plus, calculate zone energy balance manually
Hi!
I have some doubt about how to calculate a zone's energy balance manually, using EnergyPlus output variables. Using a most simple model with only walls and no window, light, equipment, people, infiltration and a simple ac this works quite well (i.e. balance is close to zero), summing up these variables:
  • Surface Inside Face Conduction Heat Transfer Rate,
  • Zone Electric Equipment Total Heating Rate,
  • People Sensible Heating Rate,
  • Zone Lights Total Heating Rate,
  • Zone Air System Sensible Cooling Rate,
  • Zone Air System Sensible Heating Rate (of walls, ceiling and floor ),
  • Zone Infiltration Sensible Heat Loss Energy,
  • Zone Infiltration Sensible Heat Gain Energy.
Using a slightly more complicated model including a window I simply added the according variable for the window:
  • Surface Window Heat Loss Rate,
  • Surface Window Heat Gain Rate,
but the balance (i.e. sum) is far from being zero. Is there any point I am missing?
Best regards
Chris
click to hide/show revision 2
No.2 Revision
Hi!
Best regards
Chris
EDIT EDIT EDIT
Hi! Thanks a lot everyone for the quick and wonderful replies. Here some more information about what I was doing as I didn't write it above.
The difference for the case I am looking gets up to 90 W / h for an about 35 m² room. What I was actually looking at is the annual sum of these values and expected it to be zero.
As far as I understand the EP manual the inside conduction should get quite close to what is actually transferred by a wall. At least in a case with more zones and an interior wall between them the both values of the two zones match quite closely. The according convective variables should give the heat transferred from the wall to the air, right?
The reason for the question is an analysis where I want to check through which surface most heat enter the zone and I fully agree that there could (should??) be a simple solution for this from the side of EP, which we have been discussing here as well. Cheers Chris
EDIT EDIT EDIT
Hi!
Best regards
Chris
EDIT EDIT EDIT
EDIT EDIT EDIT
