I'm having a problem with the Hot Water Loop in my model and I don't know what to do. I have this error: * Fatal * CheckForRunawayPlantTemps: Simulation terminated because of run away plant temperatures, too hot ...Summary of Errors that led to program termination: ..... Reference severe error count=1 ..... Last severe error=Plant temperatures are getting far too hot, check controls and relative loads and capacities
I'm using a Boiler, Chiller and a Heat Exchanger... My pump control type is Intermittent (I've seen that this sometimes solves the problem).
Thanks for the help....
