PAT or OS results?
Hi guys,
The way that I run most of my models is creating a baseline file and a proposed file on OS since I'm not that good writing or creating measures to work with a single file, then i took both files and compare them on PAT to check the EUI and energy savings.
I notice that when i run my proposed model on OS i get some results but when i run it on PAT as an alternative design For my baseline I get a completely different results, what I'm thinking is that PAT is not carrying my measures.
By the way the measures that Im using are some natural ventilation measures and an utility measure.
which of these results are more reliable, the PAT ones or the OS ones? is there a way to check that PAT is carrying the measures that im using on OS?
Thanks, Julian.
click to hide/show revision 2
No.2 Revision
PAT or OS results?
Hi guys,
By the way the The measures that Im using are some natural ventilation measures and an utility measure.
Thanks, Julian.
click to hide/show revision 3
No.3 Revision
PAT or OS results?
Hi guys,
I'm using
OS and PAT Version 1.4.0 since is a project that i have a while ago.
Thanks, Julian.
PAT or OS results?
Hi guys,
I'm using OS and PAT Version 1.4.0 since is a project that i have a while ago.
Thanks, Julian.
PAT or OS results?
Hi guys,
Thanks, Julian.
