Hi All, I have a fatal error with my EnergyPlus Modeling. Please see error details below for error details. I don't know where to look at and edit "GetSysAvailManagerInputs". Can you please help me fix this issue? Thanks so much in advance for your help! Please feel free to let me know if you need more information form me regarding the energy modeling.
Thanks again!
* Severe * GetSysAvailManagerInputs: AvailabilityManager:NightCycle="AHU-1 AHU/1 NIGHT CYCLE OPERATION" invalid Control Zone or Zone List Name="<select zone="">" not found. * Fatal * GetSysAvailManagerInputs: Errors found in input. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=1 ..... Last severe error=GetSysAvailManagerInputs: AvailabilityManager:NightCycle="AHU-1 AHU/1 NIGHT CYCLE OPERATION" invalid Control Zone or Zone List Name="<select zone="">" not found. *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages.
*** ===== Final Error Summary ===== *** The following error categories occurred. Consider correcting or noting. *** Nominally Unused Constructions *** ..The nominally unused constructions warning is provided to alert you to potential conditions that can cause *** ..extra time during simulation. Each construction is calculated by the algorithm indicated in the HeatBalanceAlgorithm *** ..object. You may remove the constructions indicated (when you use the DisplayExtraWarnings option).
*** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 137 Warning; 1 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 152 Warning; 1 Severe Errors; Elapsed Time=00hr 04min 19.72sec
