E+ AirLoopHVAC idf echo
All. May be crazy, but swore I read a feed recently talking about using a means to get an idf data echo when using AirLoopHVACUnitary object to see what all e+ creates/uses when using this construct, but cannot find this now? Am I asking gibberish?
Maybe 2 better questions would be: 1) when using the AirLoopHVACUnitary object, which has the fan/coils as part of the object, is a 'regualr' air loop with a branchlist and separate fans & coils created for simulation Or am I dreaming here? 2)Is there a way to turn on the idf echo (in a general sense)? I found some info where the ".audit" removed this as a default behavior....but I haven't had success tuning it back on yet either.....thoughts?
click to hide/show revision 2
No.2 Revision
All. May be crazy, but swore All, I swear I read a feed recently talking about using a means to get an idf data echo when using AirLoopHVACUnitary object to see what all e+ creates/uses when using this construct, but cannot find this now? Am I asking gibberish?
