I am attempting to add an air temperature adjacent to a window or surface temperature of a window in EnergyPlus. This would act as if it were a boundary condition and would be controlled by a schedule or an actuator.
I tried the SurfaceProperty:OtherSideCoefficients object but found that it does not work on walls with windows.
Is there a component I can use or an actuator I could apply to override the surface temperature of a specific window in a model?
While on the subject is there a component or actuator I can use to control the direct and diffuse radiation incident on a glazed surface.
Thank you for your time,
Justin
