Aside from the 'Surface Search' tool in the SketchUp plugin, are there any other ways to select multiple surfaces from different spaces? Currently the only way to select a surface is to first click-in to the space (which prevents the user from selecting surfaces from other spaces).
This is useful when setting constructions and boundary conditions for a specific group of surfaces, or for manipulating geometry by pulling/pushing groups of surfaces in the same plane.
I've found a few creative ways of using the surface search tool for some instances, but I always seem to end up with changes to groups of surfaces that are time consuming because the change has to be applied to each surface individually.
