I input nominal capacity in a water heating coil definition of a AHU. I input Rated inlet/outlet water temperature and Rated inlet/outlet air temperature, too.
In a AHU sizing i input the Design supply air flow rate.
The results show that nominal capacity of the water heating coil is greater than nominal capacity specified.
Why does this happen?
How can i to fix the nominal capacity of the water heating coil?
