"Process exited with non-zero exit code of: 1" when trying to apply this measure.
Using OS v 12.4 and 12.5.
DL is deprecated, please use Fiddle
E:/Program Files/OpenStudio 1.12.5/ruby-install/ruby/lib/ruby/gems/2.0.0/gems/openstudio-standards-0.1.4/lib/openstudio-standards/utilities/simulation.rb:9:in `mkdir': No such file or directory - false/SizingRun1 (Errno::ENOENT)
from E:/Program Files/OpenStudio 1.12.5/ruby-install/ruby/lib/ruby/gems/2.0.0/gems/openstudio-standards-0.1.4/lib/openstudio-standards/utilities/simulation.rb:9:in `run_simulation_and_log_errors'
from E:/Program Files/OpenStudio 1.12.5/ruby-install/ruby/lib/ruby/gems/2.0.0/gems/openstudio-standards-0.1.4/lib/openstudio-standards/hvac_sizing/Siz.Model.rb:74:in `runSizingRun'
from E:/Program Files/OpenStudio 1.12.5/ruby-install/ruby/lib/ruby/gems/2.0.0/gems/openstudio-standards-0.1.4/lib/openstudio-standards/prototypes/Prototype.Model.rb:123:in `create_prototype_building'
from C:/Users/wsdols/AppData/Local/Temp/OpenStudio.D13588/ApplyMeasureNow/UserScript/user_script.rb:130:in `run'
from in.rb:355:in `<main>'
Script executing from: C:/Users/wsdols/AppData/Local/Temp/OpenStudio.D13588/ApplyMeasureNow/UserScript Found argument 'building_type' with value 'RetailStandalone'. Found argument 'template' with value '90.1-2013'. Found argument 'climate_zone' with value 'ASHRAE 169-2006-5B'. Found UserScript 'Create DOE Prototype Building'. [openstudio.EpwFile] <0> Successive data points (1986-Jan-31 to 1987-Feb-01, ending on line 753) are greater than 1 day apart in EPW file 'E:/Program Files/OpenStudio 1.12.5/ruby-install/ruby/lib/ruby/gems/2.0.0/gems/openstudio-standards-0.1.4/data/weather/USA_ID_Boise.Air.Terminal.726810_TMY3.epw'. Data will be treated as typical (TMY) [openstudio.setFileExtension] <0> Path p, 'E:/Program Files/OpenStudio 1.12.5/ruby-install/ruby/lib/ruby/gems/2.0.0/gems/openstudio-standards-0.1.4/data/weather/USA_ID_Boise.Air.Terminal.726810_TMY3.ddy', has an unexpected file extension. Was expecting 'idf'. [openstudio.energyplus.GeometryTranslator] <0> Could not find GlobalGeometryRules object, assuming defaults [openstudio.energyplus.GeometryTranslator] <0> Could not find Building object, assuming 0 rotation [openstudio.energyplus.GeometryTranslator] <0> Could not find Building object, assuming 0 rotation [openstudio.energyplus.GeometryTranslator] <0> Could not find Building object, assuming 0 rotation [openstudio.energyplus.GeometryTranslator] <0> Could not find Building object, assuming 0 rotation [openstudio.model.YearDescription] <1> 'UseWeatherFile' is not yet a supported option for YearDescription [openstudio.model.YearDescription] <1> 'UseWeatherFile' is not yet a supported option for YearDescription Could not find .stat file for: E:/Program Files/OpenStudio 1.12.5/ruby-install/ruby/lib/ruby/gems/2.0.0/gems/openstudio-standards-0.1.4/data/weather/USA_ID_Boise.Air.Terminal.726810_TMY3.stat.
