Modeling water-to-air heat pump with desuperheater for DHW
Only simple air-cooled DX objects are allowed to be input into theheating source object type field for the Coil:WaterHeating:Desuperheater object in EnergyPlus.
I need to model a water-to-air heat pump with a Desuperheater for DHW heating. Has anyone found a workaround for this in EnergyPlus?
I'm surprised the Coil:WaterHeating:Desuperheater object doesn't support more coil types like the HeatPump:WaterToWater:ParameterEstimation:Cooling or the Coil:Cooling:WaterToAirHeatPump:ParameterEstimation coil types.
If you also think this would be a nice feature, vote here: https://energyplus.uservoice.com/forums/258860-energyplus/suggestions/16019266-add-more-dx-systems-types-to-provide-waste-heat-fo
