I'm working in a Data Center simulation project.
I have a coil for only one room, which is a Data Center. The Data Center doesn't have people and ventilation, so the Latent Load should be very small. I'm using a coil with autocalculate to calculate the needed capacity for the coil.
However, the Nominal Sensible Heat Ratio of the coil in the result Equipment Summary:Cooling Coils is 0.7. It is too high for a Data Center, so I think that there is an error.
How should I know what is the thermal latent load of the coil? Is it probable to be an error?
