DOAS Scripts Not Adding Air Loop
I am trying to use the Whole System scripts from the BCL and having difficulty getting them to generate the DOAS. I have tried a few of the AEDG measures, VRFwithDOAS, and GSHPwithDOASMoreDesignParameters. The VRF measure just erases all of my HVAC equipment on the air loop and zone levels. The GSHP and WSHP measures generate the plant loops and put heat pumps at the zone level correctly, but the measures aren't generating the DOAS.
I am fairly new to OS and the BCL library, so I apologize if I am missing something obvious.
Here are the outputs of the GSHP and VRF measures:
VRFwithDOAS:
DL is deprecated, please use Fiddle
Script executing from: C:/Users/timj/AppData/Local/Temp/OpenStudio.ys2676/ApplyMeasureNow/UserScript Found argument '90.1-2010 - Office - OpenOffice' with value 'true'. Found argument '90.1-2010 - Office - Lobby' with value 'true'. Found argument '90.1-2010 - Office - Conference' with value 'true'. Found argument '90.1-2010 - Office - ClosedOffice' with value 'true'. Found argument 'vrfCondenserType' with value 'AirCooled'. Found argument 'vrfCoolCOP' with value '4'. Found argument 'vrfHeatCOP' with value '4'. Found argument 'vrfMinOATHPHeat' with value '-4'. Found argument 'vrfDefrost' with value 'Resistive'. Found argument 'vrfHPHeatRecovery' with value 'Yes'. Found argument 'vrfEquivPipingLength' with value '100'. Found argument 'vrfPipingHeight' with value '35'. Found argument 'doasFanType' with value 'Variable'. Found argument 'doasERV' with value 'none'. Found argument 'doasEvap' with value 'none'. Found argument 'doasDXEER' with value '10'. Found argument 'costTotalHVACSystem' with value '0'. Found argument 'remake_schedules' with value 'true'. Found UserScript 'VRFwithDOAS'. result = true Processed 1 base script and 0 merged scripts
GSHPwithDOASMoreDesignParameters:
Script executing from: C:/Users/timj/AppData/Local/Temp/OpenStudio.ys2676/ApplyMeasureNow/UserScript Found argument '90.1-2010 - Office - OpenOffice' with value 'true'. Found argument '90.1-2010 - Office - Lobby' with value 'true'. Found argument '90.1-2010 - Office - Conference' with value 'true'. Found argument '90.1-2010 - Office - ClosedOffice' with value 'true'. Found argument 'gshpHeatingCOP' with value '4'. Found argument 'gshpCoolingEER' with value '14'. Found argument 'gshpFanType' with value 'PSC'. Found argument 'boreHoleNo' with value '200'. Found argument 'boreHoleLength' with value '200'. Found argument 'boreHoleRadius' with value '6'. Found argument 'groundKValue' with value '0.75'. Found argument 'groutKValue' with value '0.75'. Found argument 'supplementalBoiler' with value 'no'. Found argument 'boilerCap' with value '500'. Found argument 'boilerEff' with value '0.9'. Found argument 'boilerFuelType' with value 'NaturalGas'. Found argument 'boilerHWST' with value '120'. Found argument 'doasFanType' with value 'Variable'. Found argument 'doasERV' with value 'none'. Found argument 'doasEvap' with value 'none'. Found argument 'doasDXEER' with value '10'. Found argument 'costTotalHVACSystem' with value '0'. Found argument 'remake_schedules' with value 'true'. Found UserScript 'GSHPwithDOASMoreDesignParameters'. result = true Processed 1 base script and 0 merged scripts
VRFwithDOAS:
VRFwithDOAS:
